Support our host
News
Software
Reference
Community
Parts Library
About Us
About Us
Published By OrionP on Sunday, November 09, 2003 - 07:23 PM
Printer-friendly page
LDraw.org is a collaborative effort by users of the LDraw software program created by James Jessiman. Since James' passing, the original LDraw software package remains exclusively the intellectual property of James' immediate family.
LEGO® is a registered trademark of the Lego Group, which does not sponsor, endorse, or authorize this site. Visit the official Lego website at http://www.lego.com.
Content © 2002 LDraw.org. All content created specifically for LDraw.org, including but not limited to images, HTML code, and original unique content falls under the OpenContent Licence (OPL). Individual programs made available for download from this site are subject to their individual respective licenses and are used by permission.
Official Model Repository Disclaimer
The LDraw.org 'Official Model Repository' is a compilation of unofficial, fan-created data files. The patterns of LEGO elements depicted in these files represent intellectual property owned by the LEGO Group of companies, which does not sponsor, authorize, or endorse this compilation.
The word "official" is not meant to imply that the compilation itself or the files within it are official in any way, but rather that the data files contain unofficial representations of official LEGO products.
This compilation has been assembled primarily as reference material for LEGO enthusiasts who wish to learn more about particular LEGO sets, or who wish to generate various static or dynamic digital renderings of official LEGO models without the use of a camera.
OpenContent License (OPL)
Version 1.0, July 14, 1998.
This document outlines the principles underlying the OpenContent (OC) movement and may be redistributed provided it remains unaltered. For legal purposes, this document is the license under which OpenContent is made available for use.
The original version of this document may be found at http://www.opencontent.org/opl.shtml
LICENSE
Terms and Conditions for Copying, Distributing, and Modifying
Items other than copying, distributing, and modifying the Content with which this license was distributed (such as using, etc.) are outside the scope of this license.
1. You may copy and distribute exact replicas of the OpenContent (OC) as you receive it, in any medium, provided that you conspicuously and appropriately publish on each copy an appropriate copyright notice and disclaimer of warranty; keep intact all the notices that refer to this License and to the absence of any warranty; and give any other recipients of the OC a copy of this License along with the OC. You may at your option charge a fee for the media and/or handling involved in creating a unique copy of the OC for use offline, you may at your option offer instructional support for the OC in exchange for a fee, or you may at your option offer warranty in exchange for a fee. You may not charge a fee for the OC itself. You may not charge a fee for the sole service of providing access to and/or use of the OC via a network (e.g. the Internet), whether it be via the world wide web, FTP, or any other method.
2. You may modify your copy or copies of the OpenContent or any portion of it, thus forming works based on the Content, and distribute such modifications or work under the terms of Section 1 above, provided that you also meet all of these conditions:
a) You must cause the modified content to carry prominent notices stating that you changed it, the exact nature and content of the changes, and the date of any change.
b) You must cause any work that you distribute or publish, that in whole or in part contains or is derived from the OC or any part thereof, to be licensed as a whole at no charge to all third parties under the terms of this License, unless otherwise permitted under applicable Fair Use law.
These requirements apply to the modified work as a whole. If identifiable sections of that work are not derived from the OC, and can be reasonably considered independent and separate works in themselves, then this License, and its terms, do not apply to those sections when you distribute them as separate works. But when you distribute the same sections as part of a whole which is a work based on the OC, the distribution of the whole must be on the terms of this License, whose permissions for other licensees extend to the entire whole, and thus to each and every part regardless of who wrote it. Exceptions are made to this requirement to release modified works free of charge under this license only in compliance with Fair Use law where applicable.
3. You are not required to accept this License, since you have not signed it. However, nothing else grants you permission to copy, distribute or modify the OC. These actions are prohibited by law if you do not accept this License. Therefore, by distributing or translating the OC, or by deriving works herefrom, you indicate your acceptance of this License to do so, and all its terms and conditions for copying, distributing or translating the OC.
NO WARRANTY
4. BECAUSE THE OPENCONTENT (OC) IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE OC, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE OC "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK OF USE OF THE OC IS WITH YOU. SHOULD THE OC PROVE FAULTY, INACCURATE, OR OTHERWISE UNACCEPTABLE YOU ASSUME THE COST OF ALL NECESSARY REPAIR OR CORRECTION.
5. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MIRROR AND/OR REDISTRIBUTE THE OC AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE OC, EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
Recipient 2007
Kevin Clague
Current Contest Winners
Model of the Month
Scene of the Month
Vote for Next Month's Winner
What's new in lugnet.cad?
Re: New Project: DatShine, LDA, PreL3P, L3P, And POV Involved
by Tore Eriksson - 4 hours ago
Re: LETGUI new version 0.1.0.14
by Philippe Hurbain - 6 hours ago
by Matt Wagner - 8 hours ago
by Michael Heidemann - 16 hours ago
There are 79 unlogged users and 1 registered user online.
 Log in Problems?
 New User? Sign Up!
