©2003-2006 LDraw.org
L(EGO)Draw parts chart [1]
Posted by : Holly-Wood on Aug 22, 2007 - 03:17 PM
library [2]
The chart lists brick shapes we've got from the LEGO Universe Team. They need some clean-up to be suitable for the LDraw Parts Tracker. If you wanna contribute just download the file you want work on, but don't forget to email the LDraw Administration Team telling the part number your working on - your name will be associated with the part in order to avoid overlap.
Special attention has to be paid to:
  • New header [3] specs.
  • BFC [4]
  • Category [5]
  • Keywords [6]
  • Color correction
  • Additional primitive [7] substitution where needed
  • Stud orientation
  • Separation into subfiles where needed
  • Grouping into code sections
  • Origin in sync with the LDraw standard
Please use the following guideline for the ownership:
0 PartDescription
0 Name: Filename.dat
0 Author: RealName [UserName]
0 !HISTORY 2007-08-25 {The LEGO Universe Team} Original part shape
0 !HISTORY YYYY-MM-DD [UserName] File preparation for LDraw Parts Tracker
The parts description has been taken from Peeron.com. Please check back with the PT Admins if your part has no description or you feel that the description is not appropriate. Please understand also that only authors who have affirmed the LDraw Contributor Agreement [8] are allowed to fix these parts. Once the part has been submitted to the Parts Tracker, any reviewer finding errors may fix them immediately and re-submit the fix without asking permission, since the original author is the LEGO Universe Team.
Type Number Already
at PT?
Name (taken from Peeron.com) Cleaner
part 30632.dat [9] No Technic 6 x 4 x 3 Grill with Two Pins and Two Pin Holes
part 3278.dat [10] No Tap 1 x 2 Spout (Official part - 70)
part 33129.dat [11] No Boat 8 x 18 x 2 & 1/3
part 33215.dat [12] No Roof Piece 6 x 8 x 9 Half Pyramid
part 3496.dat [13] No Tap 1 x 2 Base (official part 69.dat)
part 40001.dat [14] No Technic Steering Yoke (Peeron number - x576)
part 40241.dat [15] No Door 1 x 4 x 6 with Window
part 41630.dat [16] No Roof Piece 6 x 6 Pyramid (Peeron number - 30614)
part 41890.dat [17] No Minifig Mechanical Arm Advanced ((Peeron number - x387)
part 47406.dat [18] No Cockpit 6 x 10 x 2 Curved
part 47976.dat [19] No Brick 12 x 12 with Holes on Two Sides and Vertical Pegs in Corners
part 47994.dat [20] No Triangle 1 x 3 with Two Pins and Two Clips
part 48002.dat [21] No Boat Mast 3 x 2 x 20
part 48005.dat [22] No Boat Mast 4 x 4 x 21
part 48457.dat [23] No Bar 2L with Two Clips and Top Antistud (Peeron number - x1154)
part 50859.dat [24] No Bike 2 Wheel Motorcycle Frame 2 x 6 x 3
part 50860.dat [25] No Bike 2 Wheel Motorcycle Body X x Y x Z with Fairing
part 50861.dat [26] No Tyre 15 x 6 Thin Tread - Motorcycle (Peeron number x1436 - Part is on PT but because of its poor quality it has to be substituted with this one)
part 52035.dat [27] No Bike 2 Wheel Motorcycle Body 4 x 8 x 4 with Fairing
part 53984.dat [28] No Minifig Mechanical Leg
part 54275.dat [29] No Technic Bionicle Minifig Barraki Torso (Peeron number - x1788)
part 55817.dat [30] No Wheel Spoked 7 x 7 x 2 & 2/3
part 57467.dat [31] No Minifig Harpoon (official part - 38)
part 57895.dat [32] No Unknown part
part 57906.dat [33] No Hinge Plate 1 x 12 with Angled Side Extensions and Tapered Ends
part 58827.dat [34] No Support 2 x 2 x 10 Girder Triangular with Axlehole
part 58846.dat [35] No Brick 10 x 10 Corner Round with Tapered Edge and Cutout (Peeron number - 5846)
part 59230.dat [36] No Minifig Mechanical Arm Straight
part 60219.dat [37] No Slope Brick 45 6 x 4 Double Inverted with Open Center
part 71128.dat [38] Yes (hold, NonCA) Electric Light Reflector Round 2 x 2 x 2/3 (Peeron number - x85) Chrome version of PT-part x902.dat. However x902.dat needs rewriting because it is a Non-CA part)
Links
  [1] http://ldraw.org/index.php?name=News&file=article&sid=490
  [2] http://ldraw.org/index.php?name=News&catid=&topic=25
  [3] http://www.ldraw.org/Article398.html
  [4] http://www.ldraw.org/Article415.html
  [5] http://www.ldraw.org/Article340.html
  [6] http://www.ldraw.org/Article340.html
  [7] http://www.ldraw.org/library/primref/
  [8] http://ldraw.org//Article349.html
  [9] http://ldraw.org//files/L(EGO)Draw_30632.dat
  [10] http://ldraw.org//files/L(EGO)Draw_3278.dat
  [11] http://ldraw.org//files/L(EGO)Draw_33129.dat
  [12] http://ldraw.org//files/L(EGO)Draw_33215.dat
  [13] http://ldraw.org//files/L(EGO)Draw_3496.dat
  [14] http://ldraw.org//files/L(EGO)Draw_40001.dat
  [15] http://ldraw.org//files/L(EGO)Draw_40241.dat
  [16] http://ldraw.org//files/L(EGO)Draw_41630.dat
  [17] http://ldraw.org//files/L(EGO)Draw_41890.dat
  [18] http://ldraw.org//files/L(EGO)Draw_47406.dat
  [19] http://ldraw.org//files/L(EGO)Draw_47976.dat
  [20] http://ldraw.org//files/L(EGO)Draw_47994.dat
  [21] http://ldraw.org//files/L(EGO)Draw_48002.dat
  [22] http://ldraw.org//files/L(EGO)Draw_48005.dat
  [23] http://ldraw.org//files/L(EGO)Draw_48457.dat
  [24] http://ldraw.org//files/L(EGO)Draw_50859.dat
  [25] http://ldraw.org//files/L(EGO)Draw_50860.dat
  [26] http://ldraw.org//files/L(EGO)Draw_50861.dat
  [27] http://ldraw.org//files/L(EGO)Draw_52035.dat
  [28] http://ldraw.org//files/L(EGO)Draw_53984.dat
  [29] http://ldraw.org//files/L(EGO)Draw_54274.dat
  [30] http://ldraw.org//files/L(EGO)Draw_55817.dat
  [31] http://ldraw.org//files/L(EGO)Draw_57467.dat
  [32] http://ldraw.org//files/L(EGO)Draw_57895.dat
  [33] http://ldraw.org//files/L(EGO)Draw_57906.dat
  [34] http://ldraw.org//files/L(EGO)Draw_58827.dat
  [35] http://ldraw.org//files/L(EGO)Draw_58846.dat
  [36] http://ldraw.org//files/L(EGO)Draw_59230.dat
  [37] http://ldraw.org//files/L(EGO)Draw_60219.dat
  [38] http://ldraw.org//files/L(EGO)Draw_71128.dat
