Support our host
News
Software
Reference
Community
Parts Library
About Us
Library
Published By Holly-Wood on Wednesday, August 22, 2007 - 03:17 PM
Printer-friendly page
The chart lists brick shapes we've got from the LEGO Universe Team. They need some clean-up to be suitable for the LDraw Parts Tracker. If you wanna contribute just download the file you want work on, but don't forget to email the LDraw Administration Team telling the part number your working on - your name will be associated with the part in order to avoid overlap.
Special attention has to be paid to:
  • New header specs.
  • BFC
  • Category
  • Keywords
  • Color correction
  • Additional primitive substitution where needed
  • Stud orientation
  • Separation into subfiles where needed
  • Grouping into code sections
  • Origin in sync with the LDraw standard
Please use the following guideline for the ownership:
0 PartDescription
0 Name: Filename.dat
0 Author: RealName [UserName]
0 !HISTORY 2007-08-25 {The LEGO Universe Team} Original part shape
0 !HISTORY YYYY-MM-DD [UserName] File preparation for LDraw Parts Tracker
The parts description has been taken from Peeron.com. Please check back with the PT Admins if your part has no description or you feel that the description is not appropriate. Please understand also that only authors who have affirmed the LDraw Contributor Agreement are allowed to fix these parts. Once the part has been submitted to the Parts Tracker, any reviewer finding errors may fix them immediately and re-submit the fix without asking permission, since the original author is the LEGO Universe Team.
Type Number Already
at PT?
Name (taken from Peeron.com) Cleaner
part 30632.dat No Technic 6 x 4 x 3 Grill with Two Pins and Two Pin Holes
part 3278.dat No Tap 1 x 2 Spout (Official part - 70)
part 33129.dat No Boat 8 x 18 x 2 & 1/3
part 33215.dat No Roof Piece 6 x 8 x 9 Half Pyramid
part 3496.dat No Tap 1 x 2 Base (official part 69.dat)
part 40001.dat No Technic Steering Yoke (Peeron number - x576)
part 40241.dat No Door 1 x 4 x 6 with Window
part 41630.dat No Roof Piece 6 x 6 Pyramid (Peeron number - 30614)
part 41890.dat No Minifig Mechanical Arm Advanced ((Peeron number - x387)
part 47406.dat No Cockpit 6 x 10 x 2 Curved
part 47976.dat No Brick 12 x 12 with Holes on Two Sides and Vertical Pegs in Corners
part 47994.dat No Triangle 1 x 3 with Two Pins and Two Clips
part 48002.dat No Boat Mast 3 x 2 x 20
part 48005.dat No Boat Mast 4 x 4 x 21
part 48457.dat No Bar 2L with Two Clips and Top Antistud (Peeron number - x1154)
part 50859.dat No Bike 2 Wheel Motorcycle Frame 2 x 6 x 3
part 50860.dat No Bike 2 Wheel Motorcycle Body X x Y x Z with Fairing
part 50861.dat No Tyre 15 x 6 Thin Tread - Motorcycle (Peeron number x1436 - Part is on PT but because of its poor quality it has to be substituted with this one)
part 52035.dat No Bike 2 Wheel Motorcycle Body 4 x 8 x 4 with Fairing
part 53984.dat No Minifig Mechanical Leg
part 54275.dat No Technic Bionicle Minifig Barraki Torso (Peeron number - x1788)
part 55817.dat No Wheel Spoked 7 x 7 x 2 & 2/3
part 57467.dat No Minifig Harpoon (official part - 38)
part 57895.dat No Unknown part
part 57906.dat No Hinge Plate 1 x 12 with Angled Side Extensions and Tapered Ends
part 58827.dat No Support 2 x 2 x 10 Girder Triangular with Axlehole
part 58846.dat No Brick 10 x 10 Corner Round with Tapered Edge and Cutout (Peeron number - 5846)
part 59230.dat No Minifig Mechanical Arm Straight
part 60219.dat No Slope Brick 45 6 x 4 Double Inverted with Open Center
part 71128.dat Yes (hold, NonCA) Electric Light Reflector Round 2 x 2 x 2/3 (Peeron number - x85) Chrome version of PT-part x902.dat. However x902.dat needs rewriting because it is a Non-CA part)
Recipient 2007
Kevin Clague
Current Contest Winners
Model of the Month
Scene of the Month
Vote for Next Month's Winner
What's new in lugnet.cad?
Re: New Project: DatShine, LDA, PreL3P, L3P, And POV Involved
by Tore Eriksson - 4 hours ago
Re: LETGUI new version 0.1.0.14
by Philippe Hurbain - 6 hours ago
by Matt Wagner - 8 hours ago
by Michael Heidemann - 17 hours ago
There are 75 unlogged users and 1 registered user online.
 Log in Problems?
 New User? Sign Up!
